02 no start - Ford Powerstroke Diesel Forum
Old 01-13-2012, 09:56 PM
02 no start
Buddy has a 02 7.3 with a no start hooked up scanner and its not finding pcm idm checked fuses relays all good. Need help as to where to go from here. How do you diagnose a bad idm if you can't read it with scanner has anyone had this problem before.
Fuel pressure 60 psi at fuel filter.
Truck is a 7.3 5 speed 350 thousand no mods.
Old 01-14-2012, 06:31 AM
Its common for the PCM to just be "un-powered" and a bad fuse overlooked (I know, you looked, I'm saying look again especially at #30-19-22). The test for a running PCM is the WTS (Wait To Start) light. Does it come on when you first roll-on the key? If not the PCM isn't running.
The fuel heater, (#30), is the most common problem. If you find it blown you'll have to unplug it from the bottom of the filter housing or it will just blow again.
Old 01-14-2012, 06:37 AM
Feedback Score: 5 reviews
Subscribing...
Old 01-14-2012, 12:40 PM
I have checked double checked pulled and ohmed the fuses even went as far as to swap them out just to verify. I tested all the relays they are working. Is it wierd that the idm would just fail. The truck was running fine shut down in its own and now no restart.
Old 01-14-2012, 03:48 PM
is the wts light on
