Still no heat . - Ford Powerstroke Diesel Forum
Old 01-12-2012, 08:40 PM
Still no heat .
i posted up a thread a week or so ago i got a 2003 f250 psd 7.3 and a couple guys told me i was more than likely having thermostat trouble , welp i went and bought another 195 thermostat cant really afford the 203 right now installed the thermostat . i drove the truck to the store probally 5 mile from the house and about 2 1/2 miles the trucks heat gage went to hot and check gage light came on so i pulled over right away and it started going right back down and heat started to worked , it worked fine for 15 / 20 mins then when i parked it and left it running it stoped and wouldnt work anymore . it does the exact same thing every time i drive it. it also will spew antifreeze when i take the cap off after its been running any ideas thanks Aaron
Old 01-13-2012, 05:32 PM
Johnny Law Brown
your temp sender could be lying to ya and it sounds like your heater core is getting air locked some how pull one of you heater core hoses off and see if you anti freeze coming out
Old 01-13-2012, 07:01 PM
he could pull the cap off and let the truck idle for a while and it should burp once the thermostat opens.
If it was me I would not have bought the lower degree if you could not afford the higher one I would of just waited.
Old 01-13-2012, 07:12 PM
well i had 12$ not 50$ kinda just want the heat to work not really worried about it being hotter i just would like to have some warm air. im not to picky 195 is what came in the truck. but yes when i get the money i would like to install the 203 since it has a few benifits for the truck
when you say burp, do you mean after the truck has run let it burp the antifreez out the lid . because everytime im driving it i can let a little air out the lid and the heat will work , could it have to much antifreez in it ? Thanks Aaron
Old 01-13-2012, 07:24 PM
Johnny Law Brown
If your letting air out your system is cavitating some how
Old 01-14-2012, 03:52 PM
blades on the water pump could be shot causing cavitation and air into the system
