turbo swap - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-09-2012, 08:49 AM Thread Starter
turbo swap
I am new to the forum, I usually search forums till i find what i need but this is just one i keep hitting dead ends on. My stock turbo on my early 99 went out due to 377,000 miles. I have come across a deal i can get a 02 stock turbo for $100.00. from what i understand i have to change the manifold, up pipes, pedistal, spyder, and phlems. Those parts would cost me another $100.00. Would someone please confirm this or point me in a better direction. Money is tight and i need my truck to go to work. Thanks
early 99 f250 superduty built transmission with triple disc convertor, dp tuner, gauges on pillar, diy intake, more to come...
powerstrokesmoke is offline
post #2 of 11 Old 01-09-2012, 09:49 AM
Tj Krawler's Avatar
I know you will have to change the pedestal.
I don't think you would have to change the plenums, or manifold.
How many miles on the 02? $100 is pretty cheap IMO. If you could get the rest of the parts for another $100, that's still cheap. (compared to a new one) I think it would take a while to find a good E99 turbo.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #3 of 11 Old 01-09-2012, 11:07 AM Thread Starter
I wanna say 140,000 the truck is wrecked. T boned in drivers side. I just wanna get everything I need off it the first time.
post #4 of 11 Old 01-09-2012, 01:42 PM
Tj Krawler's Avatar
I would at least grab the turbo, pedestal, and up pipes. Check for any movement in the turbo, but at 140k it shouldn't be bad. The E99 pipes are a little different, but I don't know how much different they are. If it's cheap, just so you don't have to make a second trip I would grab the spider and plenums. (I really don't know if you need them or not) The 99.5+ plenums are 3" instead of 2" on the E99/OBS 7.3s.
Alan
- Intake
- Exhust
- ScanGauge
post #5 of 11 Old 01-09-2012, 04:00 PM
duck fan's Avatar
You need the turbo, pedestal, spider, up-pipes, and plenums. You will need the correct sealant for the plenums that is, if you can get them off without destroying them. Riffraff Diesel: Motorcraft RTV Silicone Sealant
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #6 of 11 Old 01-09-2012, 04:30 PM
Quoted: 37 Post(s)
What do u want for that e99 spyder?
2008 f250 king ranch ccsb: spartan ndash with sotf, s&b cold air intake, 4" turbo back flo pro exhaust, amp research steps, 8" 4 linkrough country lift, 24x13" painted to match fuel mavericks on 38" nitto trail graps.
blacksmoke powerstroke is offline
post #7 of 11 Old 01-09-2012, 08:27 PM
Quoted: 37 Post(s)
i got a spyder from a 2000 ill straight up trade for the e99
post #8 of 11 Old 01-09-2012, 09:12 PM Thread Starter
Really not sure what to do... I need the truck running yesterday, but i dont wanna rush and buy something i ll regret. I wanna upgrade turbos and injectors later with big oil. Would i be better to go ahead and convert to late 99. From what i understand there are only a few options for an upgrade turbo for early 99. also are the up pipes a pain to get off and put on? I m a 100% diy er, i worked on gas burners all my life but this is my first diesel to own and work on. Could someone with a good knowledge base please point in the direction...
post #9 of 11 Old 01-09-2012, 09:20 PM Thread Starter
Or maybe go back stock and try to find a block and build a motor from ground up being the truck is pushing 378,000.
post #10 of 11 Old 01-09-2012, 09:22 PM
Quoted: 37 Post(s)
Alot more options on the 99.5 and up on just about everything
