Need help finding an oil sump fitting - Ford Powerstroke Diesel Forum
Old 01-04-2012, 09:04 PM
I am making a DIY preluber system and need to tap into the oil sump for the supply line. I have the thread type (M14 x 1.25 x 21) but I am having trouble finding either an elbow or a banjo type fitting to run a hose from.
I want to maintain maximum ground clearance and also run at least 3/8" hose from the fitting (barbed fitting at hose end is fine.)
I have found close to what I need online but not exactly what I want.
I would pull the sump and braze in a dedicated outlet if that wasnt such a bear.
Any help appreciated
