2000 7.3 problem - Ford Powerstroke Diesel Forum
Old 01-04-2012, 07:31 PM
2000 7.3 problem
Let me start off by saying I have read through the forum before posting
The other morning when leaving for work it was about 28 deg f out I warmed my truck up and headed out to work It was idling fine and I have not had any issues with starting or running like crap I drive about 30ft down the street and it dies I try to restart and no luck so I get a ride to work and come home that night and. Hangs the fuel filter I checked to make sure batts were charged and checked all fuses I also watch the Rpms go up when I attempt to start and they do so that eliminates the CPs the ate light comes on yet it will still not start some have said injectors but would it not have ran like crap before? I can't see 8 injectors all going bad any help is approceated thank you
Old 01-04-2012, 07:40 PM
With key on engine off, does the WTS light come on?
Old 01-04-2012, 07:49 PM
Yes it does
Old 01-05-2012, 04:21 AM
It'd help if you could pull some codes.
It could be the ICP, IDM, UVCHs, and other things.
