2001 7.3 Powerstroke starting problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-03-2012, 07:30 PM Thread Starter
This has been an on going problem, our 2001 F-350 Dually (7.3 automatic) used to start but you would have to give the truck some throttle as soon as it starts (about 1500rpm or so) and hold it until the oil pressure gauge rises, otherwise the truck would start missing and die. but if you started it this way, it would run perfectly fine after that. But now the truck doesn't fire at all until the oil pressure gauge comes up, and then it fires right up (if the batteries last that long).
Parts replaced include both the lower oil pump, and the high pressure oil pump, all 8 injectors, the oil check ball and spring, and the cam sensor.
Sorry if this topic has been talked about before, but any help would be greatly appreciated! as we are totally stuck on this one
Outlaw1109 is offline
post #2 of 3 Old 01-12-2012, 04:24 PM
Myers129's Avatar
what are you running for oil? i had starting problems until i went to 5w-40 mobil turbo diesel truck and now my truck starts great. also did the stancor relay mod
Myers129 is offline
post #3 of 3 Old 01-12-2012, 04:30 PM
atvrider93's Avatar
Quoted: 8 Post(s)
whats the outdoor temperature?
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
