HELPwont start read post still cant figure it out - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-02-2012, 07:58 AM Thread Starter
monsterstoker's Avatar
well i let a buddy drive my truck brought it back in running condition stayed at his house that night and went to leave the next day wouldnt start well i knew i needed to replace batteries soon i did and bought new terminals still didnt start atleast it cranked well i thought bout it and finally replaced that damn cps and fired right up drove it roughly 600 miles to funeral and back home then to work went to leave work all its doing is cranking again cant figure it out i warrantied the cps and put a new one in again cant figure it out help me please it is my daily driver
monsterstoker is offline
post #2 of 12 Old 01-02-2012, 08:23 PM
Un hook your ICP sensor and see if she starts. If it starts replace that sensor. It will cost about 200 bucks I think.
mgassel is offline
post #3 of 12 Old 01-02-2012, 08:51 PM Thread Starter
Ok where is it located at and Wat does unplugging it help
post #4 of 12 Old 01-03-2012, 03:00 PM Thread Starter
I did that today because my truck luckily just up and quit at wrk so I tried that and nothing anymore ideas guys please help need this truck
post #5 of 12 Old 01-03-2012, 04:34 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
First, what yr is your truck?
WTS Light? - do you get it when you first roll-on the key?
Tach Movement? - does the tach needle move up slightly when cranking? (this is where your yr would help, in '01 there was a change to trucks who's instrument cluster contain a Trans Temp Gauge, they aren't supposed to show cranking rpm)
Fuel - pump runs? Fuel refilling filter housing? Tank below 1/4?
Is it cranking fast enough? - it won't even TRY to start if cranking really slowly.
Is your truck "chipped"? If so, remove it as a Test.
Has the "Check Engine" been coming on at all? - codes would be the fastest way to direct you. Unfortunately, it takes a special scanner to retrieve them...
NoRalPh is offline
post #6 of 12 Old 01-03-2012, 10:13 PM Thread Starter
2000 with 120,000 miles no chip wait to start does come on fuel housing is filling up rpm do move but only to like 300 I do have 2 brand new batteries so plenty of juice
post #7 of 12 Old 01-03-2012, 10:14 PM Thread Starter
No service engine light also
post #8 of 12 Old 01-03-2012, 10:36 PM
atvrider93's Avatar
Quoted: 8 Post(s)
any smoke while cranking?
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #9 of 12 Old 01-03-2012, 10:42 PM Thread Starter
No smoke from Wat I can tell
post #10 of 12 Old 01-03-2012, 11:26 PM
atvrider93's Avatar
Quoted: 8 Post(s)
and you're definitely getting fuel to the bowl? if you haven't tried unplugging the ICP yet, try that. could also be IPR. my guess is one of those two.
is your HPOP res full?
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
