no power when on pedal - Ford Powerstroke Diesel Forum
Old 12-24-2011, 10:08 AM
01 f350 7.3 truck had hard starting problems. found 6 bad glow plugs. replaced all 8, now starts great drive good for about 1 min then still no power. no codes icp is showing 560 at idle. over 2000 when has no power with your foot into it. check fuel presure 45psi no codes. any body have ideas.
Old 12-24-2011, 10:13 AM
Only when cold does it do this?
If so, it's the EBPV. Unplug it at the base of the pedestal and see if it solves your problems.
Old 12-27-2011, 01:16 PM
i put a fuel presure gaugeback on it this morning. it has 45 psi when it starts the when you get on it it drop right off. runs like a pices of crap till presure is back up. i have the gauge at the head the front.
Old 12-27-2011, 02:25 PM
That could be it. Make sure the pump is working of course.
Good fuel filter.
You might just have to drop the tank and pull the fuel pickup foot in it and clean it.
