Shudder, low on power, tons of new parts, still issues - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-07-2011, 01:25 AM Thread Starter
I'm going to copy my issue from a post over on Dieselstop...
Shudder, low power..... - Diesel Forum - TheDieselStop.com
also been posted on PSN
Shudder, low on power, tons of new parts, still issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
Originally Posted by toomanyguns View Post
2002 F350 with 320,000 km.
Starts very easy, does not burn oil, no black or heavy blue smoke, decent fuel economy, no check engine light.
When cruising at steady speed and torque converter locks up the truck shudders. (at about 1500 rpm) If I let off accelerator pedal the shudder disappears. If I increase rpm and cause truck to downshift the shudder disappears. If I switch off the overdrive the shudder disappears. The shudder is more pronounced if I have a load in the back of truck.
I also notice decrease in power while towing or if heavy load (full fuel tank) in back of truck.
Today an extensive test drive and stationary scan was performed (Snap On scanner) and I was told that #1 and #8 injectors are bad. Mechanic said this will cause the shudder. The scan was performed while stationary.
I'm not so sure at this point.
Any advice out there?
I'm having this EXACT same issue. I've been having my buddies at my shop help me out and have been using the Snap On Solus reader for troubleshooting.
2001 F350 SRW, ext. cab 4x4 with 239,xxx miles
So far this is what has been changed in the last 2 months
8- Brand new Alliance Power AD injectors
new under valve cover harnesses with $.25 mod/gaskets
new International Cam Position Sensor
new OEM fuel filter
completely rebuilt 4R100 trans
brand new billet torque conveter
even after all this work, the truck is still acting up, and doing exactly the same thing as the OP.
around 1500rpm under load or cruise 30-45mph, the truck has a definite hiccup-studder to it. Something is definitely NOT right.
Truck is blowing a whitish/blue smoke at idle and when on the accelerator.
No engine codes
good oil pressure per the scanner
PERDEL values are 0 across the board as long as the truck is moving (#2,#8 values go up at idle)
all tests that you can do on the SNAP ON reader come back with a pass
no issues starting the truck even on cold days (30 deg this morning, no problems)
Its driving my buddies and I completely crazy, and all our troubleshooting is not helping.
Any help would be greatly appreciated
2001 F350 7.3 4x4, ext cab, long bed, 4" MBRP, RiffRaff 6637 kit, 4 gauge ISSPRO w/ Aerotech OBD gauge, DP F6, 6.0L Mishimoto I/C, completely rebuilt 7.3 .010 over, WW, RR FRx, RR FRx
99Mpower is offline
post #2 of 12 Old 12-11-2011, 02:51 PM Thread Starter
bump... any help?
99Mpower is offline
post #3 of 12 Old 12-11-2011, 05:01 PM
What is your fuel pressure have you checked that?
mgassel is offline
post #4 of 12 Old 12-11-2011, 05:09 PM Thread Starter
We checked it live on the feedback with the Snap On Solus reader. Couldnt see anything weird going on.
Whats the proper fuel pressure?
99Mpower is offline
post #5 of 12 Old 12-11-2011, 05:22 PM
I do not think you were looking a fuel pressure on the scanner you need to hook up a gauge inline.
The High pressure oil is what you was probaly seeing.
If I remember right the fuel pressure should be 50-60 psi.
I just got done taking diesel classes and checking the fuel pressure was one of the things we did a couple of times.
I have an 02 and you can not see the fuel pressure on the scanners we used and we had the top of the line snap on scanners.
mgassel is offline
post #6 of 12 Old 12-11-2011, 05:34 PM Thread Starter
i have a fuel pressure gauge that connects via a schrader valve. Is there a spot that I can hook that up to?
99Mpower is offline
post #7 of 12 Old 12-13-2011, 12:02 PM
jordanmills's Avatar
I'm getting EXACTLY the same symptoms. Contribution test shows #2 and #8 are underperforming. I replaced #2, tested again, put about 20 miles on her to clear the air out, and only #8 was reporting bad. Then I moved the known good injector in #2 to #8, put a suspected good spare in #2, drove her a ways, then ran the contribution test again. Now #2 and #8 are testing bad again.
The monitor says my high pressure oil is in expected range, but when I put her under load (especially moderate acceleration), the engine light will come on. Idle is 490 PSI, romping on her to accelerate will put her up to 2500 PSI or so.
Fuel pressure is 65 PSI.
Any ideas?
jordanmills is offline
post #8 of 12 Old 12-13-2011, 12:04 PM
Same. I don't think any of the 99-02 7.3 DITs report fuel pressure to the computer.
Not with a schrader valve. There's a couple of plugs you can pull out of the back of the fuel bowl and screw in. There are also test plugs on each head (forward by the AC on the passenger side, rear near the turbo on the drivers side) that you can remove and hook a line to.
post #9 of 12 Old 12-13-2011, 06:01 PM
Any ideas?
You either have a problem with the icp sensor, ipr valve you need to have 500 psi for it to run properly from what my diesel instructor told me.
When romping on it your pressure should be higher too.
You can test the oil pressure on the head if you have the correct gauge.
I am told the hpop hardly ever goes out
mgassel is offline
post #10 of 12 Old 12-13-2011, 11:56 PM
Yeah I cleaned out the ICP. I'm going to try rebuilding the IPR, then replacing the ICP next.
