need some guidance
i have a 99 f250, with 160,xxx that i just bought
here is the problem, at idle it sounds like a kind of knock, deff. a noticeable noise, than when u reach above 800 rpm it diminshes completely.. i believe this to be an injector, but i would assume it would smoke a bit if it was, all help would be greatly appreciated thanks, james |
It could be an injector, but it could also be in the valve train. Had a friend that chased a knock. Nothing could be found, so the tore the whole valve train apart thinking a bent pushrod. Nothing was found, so they put it all back together and the knock went away.
Could just be the #8 AD 'long lead' injector that can routinely knock with no problems.
#8 LL is an AE injector, the rest are AD's. His 99 most likely does not have a LL injector in it though.
Yea I knew it was different, but couldn't remember what code the rest were.
mine has the same problem its an 01 with 186,000 a noticable knock at idle but goes away when accelerated. I was told it was injector. it drives me crazy but it has done it for 30,000 miles now and no smoke yet.
stick your ear down to your trans bell housing your problem sounds like mine and I think my torquew converter is going out
