Smoking...smells like raw fuel... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-27-2011, 06:53 AM Thread Starter
And missing. Have replaced the turbo, all injectors, and ipc sensor but still exhibiting same problems. What can be causing the problem?
Buffalo Kev is offline
post #2 of 4 Old 11-27-2011, 12:08 PM
Johnny Law Brown
jc82chevyman's Avatar
Possibly your injector cups check your over flow res to see if there is fuel in there
2002 F-250 IH 444E
AFE Stage II
GTP38R
4" TB exhaust
35" BF Goodies
1995 F-250 IH 444E
jc82chevyman is offline
post #3 of 4 Old 11-27-2011, 07:04 PM Thread Starter
Thanks. Will check it out.
post #4 of 4 Old 11-28-2011, 05:25 PM
MDRhoads360587's Avatar
Does it smoke all the time? If it only does it on start up you may have bad glow plugs. I had this problem and found out at the dealership that I had three broken glow plugs.
2004 F-350 Lariat FX4 CCSB, Lariat, FX4
5% Tint All Around
MBRP 4" Straight Pipe
ARP Head Studs
Ford Gaskets
Sinister EGR Delete
New Oil Cooler
Cat ELC
Sinister Coolant Filter
Blue Spring
SCT Livewire
Shell Rotella T6 Synthetic Oil
Motorcraft Filters
MDRhoads360587 is offline
Tags
smells like raw fuel , smoking
