7.3 Glow Plug relay Problems - Ford Powerstroke Diesel Forum
Old 11-21-2011, 03:34 PM
Im hoping someone can help me out here, I have a 2000 Ford F-350 7.3 I just put a New glow plug relay on it and im having some issues. the old one was bad the new one i just put on acts like its stuck on. i have everything hooked up right when i turn the key on power gose to GP and I have 12v at both the small red wire and small orange wire and it never shuts off even when the key is off, but if i diconnect power from battery to GPR and hook it back up its fine untill i turn the key on again. everything i have been reading says its either the ground wire from the PCM is shorted or Just the PCM is bad. can anyone help?
Old 11-21-2011, 06:10 PM
im still looking for the same answer. relay wont shut off.
Old 11-22-2011, 05:13 PM
Check out this video I put together to show GPR operation. It sounds like the new one you have could be faulty.
Old 11-23-2011, 04:53 PM
yup figured out the new relay was bad also guess thats what i get for getting a cheap one from ebay. bought one from napa and works great now. thanks alot for the vidio it helped alot.
