Check engine light/ No code - Ford Powerstroke Diesel Forum
Old 10-14-2005, 09:07 AM
2001 250 7.3ps Check engine light comes on after start. Two occasions checked for codes but none. Starts fine but runs rough especially at low rpm.
Old 10-24-2005, 02:56 PM
Check your injector pressure regulator or your injector control pressure sensor. Mine was doing the same thing and i had to change the ipr. Mine did show a code though. Try to get someone with a good scanner to read it for you.
Old 10-24-2005, 03:29 PM
It was the UV harness. Everything seems great now. $450 later
Old 10-24-2005, 03:31 PM
Thats a kick in the pants!! Glad to hear its fixed!!
