DTC Questions/Troubles - Ford Powerstroke Diesel Forum
Old 11-21-2011, 11:49 AM
I had another thread but I think it was in the wrong spot so here is a new one. Thanks in advance for any and all help!
I had the codes ran this week end by my friend (snap on scanner) and a lot of them I am thinking was on there from a couple weeks ago when I put my new HPOP on and started it up. ICP,IPR, and HPOP related codes. I also have one for the EBPV which I keep unplugged so thats a no brainer. The P1211 is probably from 1 of 2 things from what I have read on here. 1, it is from where I put the new HPOP on OR 2 ,the new modded 17* HPOP is over pumping for what my factory (E99) injectors can take/handle. The one that has me a little confused is the P1249 waste gate. I do not have it unplugged and never have had this code before, untill recently AFTER I installed the new HPOP. I do have a boost fooler but according to my boost gage I never see over 20psi. So did I mess some thing up (possible cracked vacume line etc...) or is it another side effect of bigger HPOP and still factory injectors?
Old 11-22-2011, 05:51 AM
Anyone have this wastegate issue before?
Old 12-30-2011, 08:47 PM
double check all your lines and the valve connection electrically
