2002 7.3L code 1298 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-24-2007, 07:14 AM Thread Starter
2002 7.3L code 1298
I have a 02 7.3 that will hardly run, if it starts. it has a hard fault 1298, for IDM. I am not sure where to start, there are several possibilities. Any suggestions? Thanks
ambulance doctor is offline
post #2 of 7 Old 08-24-2007, 08:33 AM
ADMIN AND TECH
SCUFFY828's Avatar
p1298 is an idm failure code , buts its very possible you have a short harness un hooked under the valve cover , needs to run an injector buzz test but if you dont have the means to do that you can just pul the valve covers and see , had one this week with the same code , had driver side short harness loose , just keep in mind it could be either side
ITS STOCK
SCUFFY828 is offline
post #3 of 7 Old 08-24-2007, 08:40 AM Thread Starter
I did a buzz test and all injectors seemed to respond. I started it this morning and it runs better, but still has miss and fuel smoke upon acceleration. There is no MIL, but still has the hard 1298 fault.
post #4 of 7 Old 08-24-2007, 09:57 AM
ADMIN AND TECH
SCUFFY828's Avatar
did you clear the system out totally and rerun injector buzz and koeo, just to make sure , if it doesnt go away then , it is possible to be the idm
ITS STOCK
post #5 of 7 Old 08-24-2007, 12:33 PM Thread Starter
I cleared the codes and rerun buzz test. test drove unit and it never missed a lick. rechecked codes--none. seems to be perfect, but since I didn't actually do anything, I'm still suspicious. I'll run it local until the problem resurfaces...Thanks.
post #6 of 7 Old 08-24-2007, 01:05 PM
Feedback Score: 3 reviews
sometimes it will run fine until that UVC harness gets hot or shakes loose. Best bet is to pull the top bolts, pry it up and take a look..
But the first step on the pinpoint test, ask if it pops up on KOEO, if so, replace IDM.. BUt its notin front of meso have fun..
Joel
01 Platinum Edition-330k miles
Swamps 6 Pos., 200/30 Hybrids, WW1, EBP delete, ARP Studs, 910 Springs, FRx, HPX, High Flow CVD Fittings, Smith Bros Pushrods, 4" Magnaflow Stainless, ITP Fooler, EGT/Boost/Trans gauges
Ford AIS, Cowl Hood, Shaved Tailgate, 6.0 paint to match TT Mirrors, 6.0 Tranny Cooler, BTS Valvebody & Accumulator Body, Transfer Flow 46 gal tank w/ harpoon mod, AirRide Bags, Billet Grille, 03 headlights/Corners, 6k HID kit, 08 diff cover, 08 tail lights
ProStarPony is offline
post #7 of 7 Old 08-24-2007, 01:21 PM Thread Starter
I have R+R the harness you are refering to on another truck before, but not on this one. It is in an E-450 ambulance, so I will have to let it cool off before I check it out. The 1298 code has not returned on the KOEO.
