overhaul info on 01' 7.3
Can anyone tell me where I can find an overhaul manual for a 2001 F350 7.3. Had internal problems pulled the engine and will be over hauling, really need some kind of guidance to put back together. Thanks in advance for any help.
your best bet is tear it down,probly depenting on wear of the engine you will need to machine the cylinders 0.10,or 0.20 over and i would also get the heads reworked and surfaced,you will need to check you crank with a mic. gauge to make shure it doesent need to be turned,the get the master engine kit,comes with new new cam,lifters, timing gears chain,pistons,rings,bearings,oil pump,gaskets and sealsfor all you torque specs,go to you local dealer and they should be able to print out a sheet with the specs. also would have injectors serviced as well.hope this helped.
