I need some help! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-26-2011, 03:32 PM Thread Starter
Exclamation I need some help!
ok, so i have a 2001 7.3L and it wont start.
it all started with a leaky ICP sensor. so i bought a new sensor and pigtail and replaced them. project went smoothly. then, before i started the truck, i washed the old oil off the engine with the hose to verify i fixed the leak. then the truck wouldnt start.
i did not unhook the batteries while i did this job but the key was off.
i let the truck sit over night and all day to "dry out"
now when i try to start it, the fuel pump behind the driver headlight growls instead of hums. it cranks and cranks but never fires.
i looked all around for a loose wire or connection and found nothing.
all fuses under the dash and under the hood are good also.
thanks in advance for the advice.
Thunderin Jimmy is offline
post #2 of 2 Old 07-26-2011, 07:27 PM Thread Starter
