Odd injector type problems - Ford Powerstroke Diesel Forum
Old 07-23-2011, 12:39 PM
Hello,
I have a 2003 F250 7.3L manual, pretty much stoke. I actually just bought it recently. The CEL comes on during certain rpm ranges (about 1000-2000) also this happens when the truck is warm. There is also a small ticking sound almost like an exhaust leak that appears during this same time. (medium rpm range and normal operating temp). The CEL was acting this way when I bought it. I took and got the diagnostics run. The results are as follows:
P1249 waste gate controller
P1316 IDM codes (believe this was a possible overboost)
P1211 ICP Pressure
P1271 Cylinder 1
P1272 Cylinder 2
P1278 Cylinder 8
After the diagnostics the codes we cleared and after a few days another diagnostics was done when the same symptoms remain. The only codes that were given were the cylinder code 1,2,8. He was also able to pinpoint it to a possible short or electrical problem in these 3 (idk how accurate that was)
I have just replaced both injector wiring harnesses, and while doing so noticed that the solenoid above each of the 3 problem injectors was lose(able to be moved by hand and the screws nearly falling out) I obviously tightened them down. Double checked the wiring harness, put everything back and am still experiencing the same problems. I have not had a diagnostics done since.
I am looking for suggestions as to other problem areas that may cause these codes and symptoms trying to stick with electrical for now as the truck does not smoke at all runs well so I don’t believe I have a bad injector let alone 3.
Any ideas would be appreciated. Thank you.
Old 07-23-2011, 12:43 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
Could be bad solenoids on the injectors.
Old 07-23-2011, 01:11 PM
yeah I was tempted to replace the injectors all together, but it doesnt seem that I have completely lost any other them. The solenoids being that lose and for however long could be bad.
Old 08-01-2011, 01:23 PM
So I just got the contribution test done and returned with 3,4,and 5 injector as well as IDM module needing replaced. Obviously the next step will be a manual compression test (anyone have a link to a step-by-step proceedure for that?) and if that passes should I jump to injectors or try for more electrical problems?
Old 08-22-2011, 03:53 PM
It has been a while but here are the updates.
So instead of shooting in the dark I bought AE software and did the scanning and testing myself.
results showing a high to low side code on cylinders 1,2, and 8. contribution test showing cylinder 3, 4, and 5 failing. As well as P1316 the IDM code error.
So I took the VC back off. started the vehical the injectors are spitting oil like normal and nothing visibly wrong so none of them are totally dead. I did an Ohm test...all the pinouts were within .2 ohms from eachother and all within the Ford specified range. This leads me to believe there is nothing wrong with the wiring from the IDM plug through the harness into the injector harnesses, solenoids and back.
Buzz test checked out fine.
so I put it all back together and replace the grey CPS with a dark blue/purple one seems to be running the same, although initially(cold engine) the contribution test only shows cylinder 3 failing. I have to run the test with a warm engine and see if anything has actually changed.
I seem to be running out of ideas. Everything I have tried with the wiring has checked out. I have been told that the compression test shouldnt be an issue in my case as I am not losing any oil and there is no smoke as would be evident from oil slipping past the rings and out the exhaust.
So finally I broke down and ordered a new IDM, although I dont believe that to be the issue.
Any ideas, suggestions, or comments would be appreciated. If the IDM does nothing I guess I will be replacing injectors and at that time I will do a compression test since I will be right there.
Old 08-22-2011, 04:25 PM
Sounds like you are getting it figured out. Hopefully that IDM will take care of your issues..
My truck used to fail 3 & 8 until I swapped to the IH CPS.
Do you have the PN on that CPS?
Old 08-22-2011, 04:42 PM
yeah right now I am not to worried about #8 on any of the tests, just because the vehical has 196k miles and from what I have read #8 has been know to have its own group of problems.
I couldnt find the black IH CPS anywhere...so I figured might as well try this dark blue one, if it works great, if it runs the same I have a spare, and if it doesnt work im only out $20.
I am not sure the PN, but I ordered it from Tousely Ford via the suggestions on here. They were fast with the shipping and the CPS is actually listed for the previous year 7.3 powerstrokes. The Tousley site seems to be down at the moment.
Old 08-25-2011, 05:24 PM
Well I just got my new IDM. Plugged it in and no change. I believe after all of my testing I am only left with changing my injectors. The truck is approaching 200k and based on what i have seen some of the injectors have been replaced.
If anyone has any ideas please feel free.
Thnaks alot
