2002 Check Engine Light Please Help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-18-2011, 06:33 PM Thread Starter
Strokin02's Avatar
I did my auto to manual swap about a month ago and truck ran fine for about 3 weeks. Got a check engine light and i pulled the codes last friday. Pulled P0118, P1670, P1397, P0231, P0232, P0541, and P0683. I cleared the codes and saturday the light came back on but I didnt have a code reader with me so had to wait until today to pull codes. Started the truck and light went off. Tried to see what codes were in the freeze frame and could not connect with the PCM. It then threw a light again and the WTS light now stays on and the truck runs rough and has a miss. Fuel it up hard and it blows white smoke. Any Ideas???
2002 Crew Cab Long Bed
6" Fabtech
6 Bilstein Shocks
37 13.50 20 Toyo MT
Auto To Manual Swap
DP Tuner F5
Isspro Ev2 (Pyro, Boost, Trans, Fuel Pressure)
Airaid Intake
5" Straight Piped w 7" Tip
Strokin02 is offline
post #2 of 9 Old 07-18-2011, 08:23 PM
Feedback Score: 5 reviews
First,
Now, check all your fluids, and check ALL your fuses.
If you don't have any bad fuses I would pull the chip, too.
ToMang07 is offline
post #3 of 9 Old 07-18-2011, 08:28 PM Thread Starter
Strokin02's Avatar
Thank you. All fuses were good. I'll try pulling the chip.
6" Fabtech
6 Bilstein Shocks
37 13.50 20 Toyo MT
Auto To Manual Swap
DP Tuner F5
Airaid Intake
post #4 of 9 Old 07-18-2011, 08:29 PM
P1670{3}
IDM Electronic Feedback
P1397
System Voltage Out Of Self Test Range
P0231{5}
Fuel Pump Monitor Circuit
P0232{5}
P0541
Manifold Intake Air Heater
P0683
Glow plug diagnostic signal communication fault
P0118
ECT sensor circuit high input
ToMang07 is offline
post #5 of 9 Old 07-18-2011, 08:37 PM
Wow... that's a whole array of issues.
Only 1 I can see that is likely NOT an issue....
P0541
is the AIH... Air Intake Heater deleted? (A Plug in the spider?)
Other than that... i would charge up the batteries, clear the codes, and start checking wiring harnesses for a short somewhere.... first place I would check would be the wiring harness on the driver's side valve cover, right under the intake hose/CCV. It has a habit of rubbing on the valve cover and fraying the wire.
Again, i would pull the chip for diagnostic purposes, and put it back in once it's ruled out as the issue, AND after you get the issues cleared up.
ToMang07 is offline
post #6 of 9 Old 07-18-2011, 08:46 PM Thread Starter
Strokin02's Avatar
Ya i have the AIH delete. I am not able to connect with the PCM to clear the codes is part of the problem.
6" Fabtech
6 Bilstein Shocks
37 13.50 20 Toyo MT
Auto To Manual Swap
DP Tuner F5
Airaid Intake
post #7 of 9 Old 07-18-2011, 09:20 PM
Double check all your fuses, and does your cigarette lighter work? If the fuse to the cigarette lighter is bad its the same one the OBDII port uses.
You could also try this: Disconnect the batteries, (BOTH) then touch the +/- together, and let sit overnight. That might clear the codes. (Worked on my ram...haven't tried on my PSD)
ToMang07 is offline
post #8 of 9 Old 07-19-2011, 05:42 AM Thread Starter
Strokin02's Avatar
Ya i checked and rechecked all my fuses. Even replaced the cigar lighter fuse with a new one just for kicks and same thing. Unable to connect.
6" Fabtech
6 Bilstein Shocks
37 13.50 20 Toyo MT
Auto To Manual Swap
DP Tuner F5
Airaid Intake
post #9 of 9 Old 07-19-2011, 06:27 AM Thread Starter
Strokin02's Avatar
Started truck to move it this morning and light is off as WTS light working properly. Was able to connect with PCM and pulled codes P1670, P0231, and P0236
6" Fabtech
6 Bilstein Shocks
37 13.50 20 Toyo MT
Auto To Manual Swap
DP Tuner F5
Airaid Intake
