crank.. no start
my friend has a 7.3 that cranks but no start.. he has a P0603 but was told it was because he disconnected his batteries.. changed fuel filters.. he turned the key on/ engine off.. he heard the fuel pump run and has a hissing noise under the hood on the driver side behind the battery
any ideas?? is there a way to check to see if the hpop has a leak or bad?? he has started it with ether but then it dies |
possible bad crank sensor very common.. i would check that first and foremost.
Checked ALL fuses?
Is the WTS (Wait to Start) light going on/off like normal? 603 is pretty much a dummie code, from batteries or a chip, just means the saved PCM info (KAM Memory) was wiped. Nothing to worry about. |
how do u check that?? or do u jus replace it?? |
not quite sure how you check. i would just replace takes ab 25 minute at max. and get part from the dealer only runs $23.51 with tax. well here in TN thats how much just purchased my back up this morning.
I'm having similar issues. Changed cps and it started just fine a few times and then nothing. After it wouldn't start I ran the codes and got 1210 and 0123.
P0123
Accelerator Pedal Sensor Circuit High Input P1210 ICP Sensor Fault |
