cps sensor help - Ford Powerstroke Diesel Forum
Old 07-17-2011, 02:31 PM
Chapter Director
cps sensor help
Hey guys does anyone have a good pic of the cps sensor location a buddy of mine needs to see one and my truck is still at ford thanks
Old 07-17-2011, 07:33 PM
No pic but it is located on the front passanger side of the motor 1 bolt to hold it to motor if you lay or get under and look up just infront of passanger tire close to bottom of motor. if you look at the pic of your truck think just below and behind turn and hazzard light good luck
Old 07-18-2011, 01:58 PM
The Camshaft Position Sensor is located to the top left of the crank pully as you look at the front of the engine. After you take out the 10mm bolt take the flat head screwdriver and pry up on the sensor to pop it out. Just don't loose the screw but does come with a new bracket.. If i recall correctly its located right under the waterpump.. or maybe above? but its on passenger side of engine..
Old 07-18-2011, 03:25 PM
Feedback Score: 5 reviews
Welcome to guzzle's CPS R&R Web Page<
Old 07-18-2011, 03:40 PM
Chapter Director
Would yall say to buy one from dieselorings anywhere e lse to buy one
Old 07-18-2011, 03:57 PM
How bad does he need one?
I have had very good luck with Bob/Guzzle, great service and fast shipping! The black ones all seem to go for $50's.... the Gret one is like $25-30 from ford.
I should have a couple of spares here in a couple days... Only need 1.
Old 07-18-2011, 04:01 PM
Chapter Director
whats better the black or grey turned out it wasnt that he was just freaking out for noth bad alt lmao
Old 07-18-2011, 04:12 PM
Depends who you ask, but from what I have read the International Black one is th ebest, or the Grey Ford one. (The recall CPS.)
