Ok so my oil cooler was leaking so i got new o-rings for it and I am in the prossed of reassembling it. For some reason I can not get the front header part of the oil cooler to seat back on over the o-rings. I have put oil on the o-ring and put all my weight on it (255 lbs) and it just pops right off. It feels like it is seated or bottomed out and then when I take pressure off of it it just pops off. Whats the deal?
Help bump...
bump??????
http://i1216.photobucket.com/albums/.../oilcooler.jpg
The top part is the piece I can't get to go back on. |
Maybe try using something more than oil to lube the o rings and parts. Syl glyde from NAPA or maybe vasoline or plumbers faucet lube. Also have read about guys using a clamp or strap to seat the ends. Good luck.
you need to use a soft hammer of some type and tap that end cap on...
sorry i didnt see this sooner. it was the same process when i did my oil cooler with new rings and tube. |
Thanks guys, I used a ratchet strap and it went back together real easy.
| Tags |
| 7.3l powerstroke, gasket, o-ring, oil cooler |
