rusty oil pan - Ford Powerstroke Diesel Forum
Old 07-08-2011, 02:07 PM
rusty oil pan
I have a nasty rusty oil pan on my 02. Should have noticed this sooner. It looked like it was only one spot but is actually rusting under the paint . As of now its not leaking. I was told the engine has to come out of the truck to change it. So what options are there in terms of paint or coatings to seal the pan, maybe stop it from rusting all the way thru?
Old 07-08-2011, 03:30 PM
I also have this problem and will be doing the job sometime this summer. I've researched and will be trying the KBS rust paint. A few members on here have used it and had good results.
They sell a cheap sample kit which apparently has enough paint for about 2 or 3 pans, so that is perfect if you don't want to buy a ton of the stuff.
KBS System Sampler - Stop Rust Paint - KBS Coatings - RustSeal
Here are some pics of the finished product on a 7.3 oil pan -
Old 07-08-2011, 03:48 PM
Feedback Score: 5 reviews
I need to do mine this summer. I need to get a grinder sanding disc and some paint, just debating whether to wait till I need the oil changed and do it then, (as well as add the fumoto valve, ) or do it now and just work around everything. Getting done this summer, either way.
Old 07-08-2011, 07:25 PM
rust
Looks like a good product. Im a bit concerned about sanding too much and going right thru it! I have heard of a thing called rust bullet, still looking in to it. I guess this is a common problem?
Old 07-08-2011, 08:19 PM
If you live in the winter-belt, Yup!
Old 07-08-2011, 08:56 PM
Send a message via AIM to PowerstrokeTech82787
7.3 oil pans are EASY to replace! I love doing them, they pay like 12 or 14 hrs to do, and i can do them in 3hrs. taking my sweet time.
All you have to do is get a new pickup tube gasket, Grey RTV silicone from ford, a caulk gun, oil pan, tranny jack, lift, and your in business. I pull the trannys out, transfercase connected, then take 3 dead man jacks or if i cant use them, i use 1 2x12 for the front crank pulley and 2 4x4 posts on the dog ears on the back of the block. lower the truck til the engine cant go any higher, in the mean time the oil pan is curing from the ford high temp coating i apply to it, and then i zip the pan bolts out, go up in with a flex head ratchet wrench and remove the pickup tube nuts, drop the pickup tube in the pan pull the pan out. take my die grinder to the block with a cookie wheel, scuff it up nice, and brake clean the hell out of it, put a sander wheel on my die grinder and scuff the pan rails to make the rtv have something to stick better to instead of a painted smooth surface, spooge it up, get the pickup tube gasket on, put the pickup tube in the pan, put the pan up on the cross member, put the pickup tube in first, then the pan and run the bolts home. by the time your done putting the tranny back in and everything else, the RTV should be cured IF its above 70* ambient temp. If its cooler than that i let them sit over night with no oil in them.
And rear main seals. LOVE doing them. Rear main seals, rear timing cover reseal oil pan they all pay BIG money and are fast easy jobs. C tech work.
Old 07-08-2011, 10:55 PM
Feedback Score: 7 reviews
awesome.
Old 07-09-2011, 08:24 PM
ouch
That is ugly> Looks worse then mine, but mine has the rust where it curves from the bottom to the side.
Old 07-09-2011, 11:11 PM
Really? I thought his looked pretty good. Haha, mine must be worse than I thought. Mine is like yours though, rust on the curve. I think it's close to being rusted right through in a few spots. I'm scared to pull it all off and see what's left. lol
Old 07-10-2011, 01:14 AM
That sounds much easier than removing the cab!!!
