rough idle and blue smoke at start - Ford Powerstroke Diesel Forum
Old 06-26-2011, 07:21 PM
i can start my truck in 90 degree weather and it smokes WHITE and can smell raw fuel,when first started, it and 03 7.3 170,000 miles,where should i start with glow plugs,injectors,not losing and oil or coolent,no fuel in oil.thanks for and help.
Old 06-27-2011, 05:33 PM
any help please
Old 06-29-2011, 10:14 AM
Check for fuel in coolant its hard to see if you have yellow coolant but if so it could be injector sleeve.
Old 06-29-2011, 03:18 PM
i checked no fuel in coolent,gonna bring it to the dealer and let them run an cut out test on injectors.
Old 07-03-2011, 06:24 AM
is it just blue smoke? when was the last time you changed the fuel filter? my truck was doing the same thing and it was just a dirty fuel filter! put some diesel klean in it and change ur filter drive it around it might just be that..
good luck!
Old 07-03-2011, 02:03 PM
I have changed my filter and put some lucas injector cleaner,helped a littel but still smoking blue at start till warms up and when i hammer on it blow a puff of blue smoke,and can smell raw fuel all the time,im really thining its an injector.
Old 07-03-2011, 04:50 PM
Johnny Law Brown
if your smelling raw fuel all of the time I would bet on injector cups
Old 07-03-2011, 07:20 PM
can you replace them with out removing the heads
Old 07-03-2011, 07:39 PM
Yes. If you can find the tool it is fairly simple. I did mine in a day. Some were easier than others. But all in all I saved myself a lot of money and learned a new task for all my buddies trucks.
Old 07-03-2011, 07:41 PM
If you want to my the tool it is made Whitaker. I think "Whitaker sleeve puller" Google it. I just used a tap and slide hqmmer though. And to install them an old injector minus solenoid. Good luck.
