00 7.3 wont start - Ford Powerstroke Diesel Forum
Old 06-26-2011, 04:37 PM
00 7.3 wont start
i have a 00 w a 7.3l,edge juice w attitude,over boost eleminator,4 inch straight piped,been starting hard for about a month(cranks and cranks then started) and ran fine once started,then one day it started hard as normal drove for 5 miles once warmed up shut it off and it wouldnt start again,i thought it was a fuel filter,changed it and no staart,gave it a small puff of carb cleaner it cranked for a bit then started drove for 5 miles ran fine then stalled,wouldnt start back up,charged batteries same result,waited till next day gave samll spray started and ran for hour shut down and now wont start at all,its got fuel and hpop resevoir is full,my oil gage takes a long time of cranking before it comes to normal and still no start,it has a new cps in it,no smoke outa exhaust and no blown fuses,any help would be greatly aprec thanks
Old 06-27-2011, 02:16 PM
i have kinda the same problem but i have white smoke comimg out of the tailpipe and it will start or fire like its going to start then die ???
Old 06-27-2011, 02:43 PM
i recently did head gaskets with completly rebiult heads with new injector seals,the head job has about 7k on it
Old 06-27-2011, 02:53 PM
Feedback Score: 5 reviews
Try unhooking your ICP, see if it fixes the problem. If that doesn't work, try unhooking the MAT, (In the front of the spyder.)
Is your WTS light coming on/off like normal? How long is it on for? Have you tested your GPR?
Sounds like you really need to get it scanned by a good code reader.
Old 07-03-2011, 07:55 PM
Any leaks.
Old 07-06-2011, 01:42 PM
i unhooked the icp and the mat and got no results and the wts light is working as normal,i hooked it up to a good scanner and accidentally erased the codes before i got to read them,is there a way to trick the comp to get the codes to come back up,i dont see any visible leaks
