napa/autozone harmonic dampers ok? speedi sleeve? - Ford Powerstroke Diesel Forum
Old 06-20-2011, 12:17 PM
I have a 2001 bone stock f250 that has developed a leak from the front of the LPOP. I cleaned it up pretty good with brake cleaner yesterday and layed under the truck for about an hour until I saw the oil leaking down from the seal of the lpop on onto the inside rim of the harmonic balancer/damper at which point it gets flung everywhere.
Anyhow I am picking up a mellings LPOP from the local parts house. And sense I am guessing that the seal has worn into the dampner I need to pick up either a speedi sleeve (which I have had bad luck with) or a new damper from napa. they run about 100-150 for a
Dorman/Harmonic Balancer
Price: $98.99
Part Number: 594-124
Pioneer/Harmonic Balancer
Price: $130.99
Part Number: DA-4452
Really no sense going to a fluiddamper or ATI so I figure spend 100$ on a new damper and bypass the speedi sleeve if there are no KNOWN issues with the aftermarket ones.
Thanks1!
Old 11-27-2012, 06:01 PM
I am going with the dorman one. It appears that reuse the ford part and rebuild it.
