Oil Dipstick handle broke off -> metal piece stuck inside - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-08-2007, 02:32 PM Thread Starter
blanco's Avatar
Question Oil Dipstick handle broke off -> metal piece stuck inside
My handle to the oil dipstick broke off... leaving the actual dipstick inside the tube.
I've searched and this hasn't been posted yet.
What is the best solution?
Remove Oil pan and push it out?
Remove nut on housing to oil pan (next to starter)?
Magnet to remove dipstick thru top???
thx
blanco is offline
post #2 of 10 Old 08-08-2007, 02:35 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Ouch that hurts. Can you get at it with a pair of needle nose? Cant pull the pan without pulling the motor out so that option is out. Hmm Im sure someone will have a good option for you.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 10 Old 08-08-2007, 02:36 PM
Brian's Avatar
how far down is it, you may be able to get a needle nose plyer in there to pull it out.
brian
05 f350 crew, longbed, 4x4, 68k, lariat
Brian is offline
post #4 of 10 Old 08-08-2007, 02:38 PM
Brian's Avatar
im not sure how the dipstick tube is attatched to the motor, but you may be able to take the tube off too
brian
Brian is offline
post #5 of 10 Old 08-08-2007, 02:43 PM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
Just pull the dipstick tube out. What year truck is it. I know 99.5 thru 03 7.3's there is one nut that holds the tube on right next to the ac compressor. remove that nut and pull the tube out. remove dipstick replace tube. Mine has done that to me as well. My belt went to pieces and sheared off the handle. It is a stupid place to mount the dipstick isnt it!?!
On suggestion. before removing the tube clean the area on the block where the tube goes in. It is kinda hard cause the starter is in the way but mine had a bunch of gunk built up and I cleaned it before removing/reinstalling cause I didnt want that gunk to get into the oil pan.
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #6 of 10 Old 08-12-2007, 10:30 AM Thread Starter
blanco's Avatar
Ok. I removed the nut holding the bracket and pulled on it a bit, but doesn't seem to budge.
It is a 2000 model btw.
blanco is offline
post #7 of 10 Old 08-12-2007, 11:22 AM Thread Starter
blanco's Avatar
Thumbs up
Holy Crap... It works!! I just had to tug a little harder. It is held in place at the oil pan with an o-ring.
I can finally check my oil.
Thanks to the folks that helped.
blanco is offline
post #8 of 10 Old 08-12-2007, 03:25 PM
Feedback Score: 3 reviews
FYI: NEVER undo that giant nut beside the starter that is in the side of the oil pan. The other side in the pan will fall if you take it out and removal of pan means removal of motor to get to it in the pan.
Joel
01 Platinum Edition-330k miles
Swamps 6 Pos., 200/30 Hybrids, WW1, EBP delete, ARP Studs, 910 Springs, FRx, HPX, High Flow CVD Fittings, Smith Bros Pushrods, 4" Magnaflow Stainless, ITP Fooler, EGT/Boost/Trans gauges
Ford AIS, Cowl Hood, Shaved Tailgate, 6.0 paint to match TT Mirrors, 6.0 Tranny Cooler, BTS Valvebody & Accumulator Body, Transfer Flow 46 gal tank w/ harpoon mod, AirRide Bags, Billet Grille, 03 headlights/Corners, 6k HID kit, 08 diff cover, 08 tail lights
ProStarPony is offline
post #9 of 10 Old 08-12-2007, 03:59 PM
Lowboy's Avatar
Now that, right there is the best suggestion you can get unless you want to pull the motor.
The o-ring is what keeps it snug in the receiver assembly for the tube. It's a common o-ring so if it's torn replace it. The nut up on the front valve cover bolt holds the tube in with the attached bracket.
You can use the (easier to check oil) late tube (99 up) in the earlier 7.3's but DO NOT loosen the big nut up to align the tube. Just leave the dip stick in the tube and carefully bend it (no kinks) to align the front bracket up to the front valve cover hole. With the dip stick out the tube might take a bend the dip stick doesn't like. If that happens the stick will not slide through the tube and it will have to be trimmed to fit.
96 F250 Nathan Amtrack Horns, Jacobs 4.5" air exhaust brake, 4" DP, to 5" with 6" stack. Bronco tank, Fass fuel with A1000 pump to Alliant 530 injectors, regulated return. Spearco BWD intercooler, H2 turbo for now, twins later. WOP long block, firerings, rev kit, Cunningham rods, Terminator HPOP's, Suncoast, Gearvenders and more stuff coming.
Early 99 F250 Lariat mostly stock for now
Work truck, 98 Peterbilt 379 Cat 800 marine motor OR6051 turbo
Support our Troops
Lowboy is offline
post #10 of 10 Old 08-12-2007, 04:45 PM
Quoted: 5 Post(s)
Sweet glad you got it fixed!
John Wayne
REDNECK VALDEZ
You can find me on
