blowing fuse 45 no pedal! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-08-2007, 02:11 AM Thread Starter
My 2002 250 keeps blowing fuse #45. truck will start and idle but I have no gas pedal, also the instrament cluster goes out. I replaced the pedal and relay with new one, did not help. now what?
pjoris is offline
post #2 of 4 Old 08-08-2007, 02:57 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
if this truck is an automatic , you need to pull the steering column cover off and find the wires coming from the button on the end of the shifter , thosed wires rub the top of the steering column , blowing the fuse and the pedal is on that circuit, the wire chaffed may just be a small spot , but thats your problem
ITS STOCK
SCUFFY828 is offline
post #3 of 4 Old 08-09-2007, 01:29 AM Thread Starter
You were right, thanks
pjoris is offline
post #4 of 4 Old 08-09-2007, 03:02 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
good deal , glad you got it fixed
ITS STOCK
