no start after fixing hpop leak - Ford Powerstroke Diesel Forum
Old 05-31-2011, 12:04 PM
had a oil leak on the hpop at the drain plug. well i ended up taking it all out cleaning it up changing all the orings reinstalled everything and now wont start. i have oil pressure and fuel. ive also filled the oil pump. made sure the gear was right (cant realy mess that up). im stumped
Old 06-01-2011, 05:18 PM
I think you an I might be in the same boat. If you look at my post, "HELP, what did I screw up," I have what sound like to be the same exact issue. Unfortunetely after reviewing the non-serviceable plug instructions, I do not think I installed the check ball correctly. If you refer to diesel o-rings website for the plug replacement, I am pretty sure I did not have the HPOP in the correct orientation when I re-assembled it.
I really dont want to, but it looks like I am going to have to tear everything back out to fix this. Hopefully I didnt ruin the check ball or anything else. I am pretty sure this is my problem, but please private message me if you find anything else. I will let you know if that fixes my problem.
Good Luck,
Old 06-02-2011, 09:55 AM
well i got it somewhat fixed. now i can only start it when i unplug icp. when its pluged in itll only run a min then shut off. what are some causes of this?
