2000 F250 died, no power to fuel pump????
Hey guys, was driving my truck yesterday and came up to a stoplight and the truck died. No signs of it running bad or anything just died. Had it towed home and started looking at it last night. I changed the cam sensor, no effect. I then checked to see if the fuel pump was running, nothing so i replaced that still nothing. SO i decided to start testing the power wire and found that the plug wasn’t making good connection. So i cut the plug and reconnect the wires still nothing. What’s next??????? im trying to test fuese and relays now thanks kyle
Just realize, your pump is not powered All the time. The PCM turns it On/Off, through a relay, and the only time you're likely to see power in that wire is for the first few seconds after you roll the key from Off to Run.
If there's still no power then, then I'd be looking at the Fuel Shut Off (safety sw) behind the passenger "kick panel", then a fuse, then the relay (I think it's behind the radio in a 2000) |
Do you have a scanner or programmer to read codes?
I ask because my truck did the same thing. Just died. Got it home and I went to hook up my programmer, it said it couldn't communicate with the truck. Led me to believe the PCM toasted. The shop tested it and sure enough, dead. $640 (parts and labor) later - all better!!! I did the KOEO thing to listen for the pump as described above, no sound, no vibration. Not saying yours is the same, but the symptoms sound familiar. |
Yea, thats the only time i check for power. i have someone is the cab switch the key on and off. I already check the saftey switch its down not in the up position. thanks kyle |
Antoher thing is i dont have the WTS light on my dash??? |
Next, if you any type of tuning, remove it as a test. Then be sure the PCM connector is tight & dry.... |
Problem fixed! ! Pulled pcm and took chip out, fired right up. Only prob is truck is slow as **** lol thanks for the help guys. Kyle
ok guys been running the truck without the chip for a month now. I need to put it back in truck is slow as helll lol. Now what do i need to do to clean the computer and terminals? whats the best way to get it all clean and keep it clean? tape the hole shut on the computer once chip is back in?
thanks kyle |
bump. . anyone
