Help, mystery leak....with pics - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-26-2011, 07:35 AM Thread Starter
I'm a bit stumped on what's leaking. I don't believe it to be oil because I'm due for a change and can see that the engine oil is black. The fluid leaking is just about crystal clear. It's coming from the tq converter cover so I pulled the cover off, and now I can see it drip from the lip of the oil pan directly below the rear main seal. I don't think the rear main is leaking as I would expect a much darker fluid since my oil is ready for a change. I'm new to this truck but I'm also guessing that the turbo uses engine oil so I don't think it's the pedestal either. Correct me if I'm wrong, not 100% sure about that statement.
My first thought was either brake fluid or power steering fluid. I checked the level of brake fluid and it looks fine. Also pumped up the brakes to see if it would leak faster but it did not.
Power steering fluid....has a red tint to it so it's not that
Trans fluid...nope, it's tinted red as well.
Diesel fuel...doesn't smell like diesel at all and the consistency is more like brake fluid.
The truck is an automatic so there is no hydraulic clutch to leak.
Looking at the pic showing all the fluids. The only one it looks close to is the brake fluid. Is there another fluid I have over looked?
RickO is offline
post #2 of 6 Old 05-26-2011, 07:41 AM
Quoted: 3 Post(s)
is there any fluid in the valley?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 6 Old 05-26-2011, 08:19 AM Thread Starter
Very hard to tell with all the acorns, leaves, and what looked like the remains of a small animal down in there. Just finished cleaning it all out and letting a little degreaser work in there for a few minutes. Getting ready to wash it out and let it run for a little bit to see if I see anything new. Stay tuned...
RickO is offline
post #4 of 6 Old 05-26-2011, 09:41 AM
OverkillMotorsports's Avatar
My guess would be diesel and the fuel o-rings on the y lines needing replaced. How many miles are on the truck?
1995 Ford Powerstroke F-250 4x4
Regular Cab Dually
Mods:
44" TSL super swampers
F150 Lariat seats
AFE Stainless exhaust
Hydroboost
Hi-Steer arm with drag link
Gauge faces all switched to white
3 POD pillar with Boost, EGT, Fuel Pressure
5.5" Shackle Reversal Kit
Southbend Single mass flywheel conversion
Southbend CON-OFE clutch kit
Tony Wildman 6 position chip
OverkillMotorsports is offline
post #5 of 6 Old 05-26-2011, 10:23 AM Thread Starter
mileage is at 133k. I've always smelled a little fuel so I'm sure you are correct about the o-rings. This is the first time I've seen evidence that they're leaking bad enough to spot the driveway.
Now that it's all cleaned out, I can see wetness in the valley but I'm not certain that it's not still a little water from the clean out I did. I may have to wait until this evening or tomorrow to know for sure. I'm pretty much going with the fuel theory since I've ruled out the brakes.
Where is the best place to get the o-rings and what else is good to do while I'm in there? Have a link to a guide with pics on replacing the o-rings?
Thanks
RickO is offline
post #6 of 6 Old 05-27-2011, 08:41 PM
sethc24's Avatar
Replacement O-rings for Ford Diesel Engines
or
Riffraff Diesel
sell them too.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
