01 7.3 with Vegistroke & Hypertech real bad running problem.
Hi guys,
I have a mix of problems here which I'm not sure if they are conected or not. I have a Hypertech tunning computer on my truck & have run on stage 3 for over 3 years with no problems. I have a Vegistroke V3 which I installed in the summer 09. Ok the main problem is that when I accelerate hard instead of getting thrown back in the seat like I've been used to, you can watch the rev counter climb then all of a suden it feels like the truck is choking itself & the revs actually come back down. If you lift your foot off the throttle a bit the revs climb bk up again. The power has almost disapeared from what it used to be like. The above happens on either diesel or on veg. The other problem only on diesel is that sometimes the truck dies as if its running out of fuel. If I flick the V3 on & leave it on or flick back to diesel the truck runs fine for mins, hours or even days. I have a leak in my veg tank now so have only been running on diesel for the last few weeks & the veg tank is empty. The truck has completly died on me the last two days as if it runs out of fuel. If I start it a few times after a while it runs ok again for a while. Yesturday it died on me in a real busy part of town. I flatened the batteries trying to start it. After a buddy came with a car to jump off of it still wouldnt start. As usual crowds were gathering as you don't see these trucks here & my truck allways attracts lots of attention. I was just about to give up & run away when I flicked the V3 switch onto manual & heard the pump run (no veg in tank though) then back to diesel the truck started.I drove home & parked it up. I had to take a gamble & go out again & it did the same thing. I turned round & limped home. It felt like it was running on about 5 cylinders. If you floor the throttle it splutters & pops like a ***** & smokes too. My hypertech computer is throwing codes saying Internal control module Kam error keep alive or something like that. It also said high exhaust presure the other day. Is the Internal Control Module the "IDM"? Ive found a place on ebay USA that refurb them. I tried to turn the tunning back to stock on my Hypertech, but when I looked to see what it said for current tunning setting it just said "????" where as it usually says "stage 3". Any help on this would be great because there isn't much help over here on these trucks as it is & I think I'm the only Vegistroke user in the UK if not Europe. My truck is my living so I'm shafted without it. I heard about a valve in the exhaust.. Where abouts is this? Also where is the IDM on the truck? |
I run alot of trucks on vegi and most of the time it's clogged filters or air. Tighten all your hoses and connections. Look for the smallest crack in a line. Vegi tends to wear out fuel lines pretty fast. Check any line that runs both diesel and veg that may be an original diesel line.
This sounds like what happened when my CPS went bad cheap and easy fix
Thanks for input guys.
All filters are new including the pre filter on the V3. Check valves on V3 are new & the o rings on the check valves. The pressure switch is only about 6 months old too. I strugle to understand all these abreviations you guys use on here. I understand some of them. I guess you mean Cam Position Sensor. I have one of those. I'll change that today & see what happens. Let you know later... |
Well I fitted a new Cam Position Sensor today & it is still the same..
Runs like a *****! |
Any help on this would be great guys...
