Lost steering and brakes at the same time!!!! - Ford Powerstroke Diesel Forum
Old 05-01-2011, 08:33 PM
My 7.3 has been letting me down a lot lately.....I was driving down the road and lost my power steering and brakes and about a 1/4qt of fluid. the tow truck driver told me it was some hydro boost hose has anyone else had this problem?? or can someone point me in the right direction of where to start?
Thanks.......
Old 05-01-2011, 08:51 PM
What kind of fluid did you loose? Brake or power steering? Because the two are seperate from each other. The power steering has it's own pump. The brakes can be affected by the vacuum pump.
Old 05-01-2011, 08:54 PM
pretty sure it was power steering fluid. it was red. I just dont understand how i lost both at the same exact time
Old 05-01-2011, 09:02 PM
because if your hydroboost isnt working, your brakes wont either.. and yes ps fluid is just atf.
Old 05-01-2011, 09:40 PM
On your truck... Superduty's have hydro-boost brakes that run off the power steering pump.
Hydraulic pressure from the pump goes to the steering box, and then to the brake booster before returning back to the reservoir.
