1999 F350 7.3L PSD Fuel System Question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-22-2011, 04:44 PM Thread Starter
'Water In Fuel' indication. Fuel filter replaced at local Ford dealer less than two months ago when serviced at 72,000. Fuel filter housing drain valve was plugged, used pipe brush to unplug. Brush came back out of drain port covered with a 'coagulated spoogee'. Draining the filter housing did not clear warning indication. I installed a new fuel filter and restarted truck and warning still did not clear. When old/new filter was removed did not see any signs of water in fuel? Question #1: could the 'coagulated spoogee' accumulated at the bottom of the fuel filter housing cause the sensor to give a false reading (water)? Question #2: if I pull the fuel filter housing to clean the crap out is there a way to test/measure the sensor (ohm/resistance) to see if it has failed? Or just replace since I have it apart? Any help would be greatly appreceiated!
RJohn29569 is offline
post #2 of 3 Old 04-22-2011, 06:30 PM
Quoted: 3 Post(s)
are you sure there is not water still in the tank?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 3 Old 05-04-2011, 09:58 PM
Put in a racor filter water seperator in line on the chasis From tank before the fuel pump.Ther is a kit availibile around $150 cause if you have a bad fill of fuel with any water content you are looking at various issues down the road.Another on of Fords crap designs to only have a suction screen in tank and one filter.Pull your tank and make sure the inner lining isnt comming apart also.
OKANE1 is offline
