99 F350 Fuel leak on shutdown - Ford Powerstroke Diesel Forum
Old 04-21-2011, 08:39 PM
My 99 F350 7.3 starts and runs great but I get a large puddle of fuel on the ground after shutting it off. I just replaced the fuel filter and new drain valve and O-rings but that didn't help the problem. It doesn't leak when it's running - only after shutting it off. Anybody had this problem or know of a fix? One member found a pinhole in the FF housing (mine was clean/no corrosion) and one had a leaking line from the fuel pump. Is the fuel return line is this area?
Old 05-02-2011, 08:50 AM
I was too impatient! Looks like my continued leak was residual fuel laying around in all the nooks and crannies. It finally cleared up and running dry now wothout any leaks.
Old 06-06-2011, 04:32 AM
if not their is a fuel return line that runs from injector pump to pass side head .it twist and turns and runs under the turbo .on turbo pedestal their is a flat steel strap that holds the line.right on the sides of that clip ,over time it rubs a hole in the lo psi return line.at shutdown it drains out.btw it is a real pain in the *** to do.i had to do mine with a foot of snow on the ground and 15dg.no room to get a wrench on the nut on back side of head.(had to chop up a good snap on to get it)
Old 06-06-2011, 05:09 AM
Thanks big pipe! My "post fix" problem was residual fuel in the "valley". After I mopped it all up she's running dry. Just took it on a 2000 mile road trip and it ran great - no leaking. I'll keep in mind the return line if I have to hunt down another leak.
