01 7.3 Powerstroke starts fine cold; after 10minutes then MIL on and runs rough. - Ford Powerstroke Diesel Forum
post #1 of 19 Old 04-18-2011, 10:19 AM Thread Starter
New to site, and new to working on diesels. Have read forum last few weeks, but still no luck. Here’s the story:
Starts fine in morning and runs well. Then after 10 minutes/5miles, the MIL "service engine soon" light on and runs rough. Next day same thing, repeated this 3 times in a row now. 4 hours later (lunch) still runs rough with MIL, and 6 hours (go home) still rough with MIL. Try OBDII scan, but no codes, even tried while running and MIL came on, but still no codes.
Van is 2001 E350 7.3 Powerstroke Turbo Diesel. It has had Biodiesel conversion added, and run B20 sometimes. It did break down on me a couple months ago. Think out of fuel, but still 1/8 on gauge. Filling and starting took 30 minutes to get it going. Opened fuel filter housing, and put back together. Been running rough (when warm) ever since.
After looking at forum, have many ideas, but can someone help narrow and prioritize this list?
- Air in Fuel Lines: ran 30 miles with no improvement, runs good cold. Would a air leak match with symptoms.
- Valve Harness UVCH(under valve cover harness): nothing tried here yet
- Valve Cover plug: nothing tried here yet
- CPS (Cam Position Sensor Recall 07S57): mine already replaced.
- HPOP high pressure oil pump: checked oil and with ¾” to top, ran with nut slightly cracked and a little oil comes out; oil tank level good
- IPR Injector Pressure Relay: nothing tried here yet, but sounds like this was fix to similar symptoms from others
- MAP Manifold Absolute Pressure: idle to full throttle is 30in to 50in (same when MIL on or off)
- ICP Injection Control Pressure sensor: nothing tried yet here
- Fuel Additive: just put some in tank about 15 miles ago
E350Sportsmobile is offline
post #2 of 19 Old 04-18-2011, 10:29 AM
CowboyCody's Avatar
Quoted: 3 Post(s)
you got a good list started there. i doubt you would still have air in the fuel lines though. if the check engine light came on you should have a code, maybe try a different scanner.
I would check the wiring harnesses first, its free and not too bad to do. kinda makes sence the UVCH could be getting coated with oil after a few minutes and shorting out. Im not a pro but i would start with those two and move on from there.
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
post #3 of 19 Old 04-18-2011, 10:49 AM
obd 2 scanners wont ork on these trucks
2008 6.4 f250 lariat 4wd
melmount is offline
post #4 of 19 Old 04-18-2011, 11:05 AM Thread Starter
Thanks for quick reply.
Cody- when checking harness, what should I look for and do?
Melmount- the OBD II seems to hook-up fine, just haven't read any codes. Is there other scanners to use?
post #5 of 19 Old 04-18-2011, 11:16 AM
2003kingranch's Avatar
you could try to go to the parts store and use their scanner
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #6 of 19 Old 04-18-2011, 11:33 AM
parts store scanners are obd2. You need autoi enginuity or a snap on scanner. The obd2 will plug it but it reads nothing. Ford diesels do not coincide with standar code readers. Muyt be 7.3 specific
melmount is offline
post #7 of 19 Old 04-18-2011, 01:07 PM
CowboyCody's Avatar
Quoted: 3 Post(s)
I know the plugs can kinda burn off on the inside, besides that just look for the basics, frayed wires or loose connections or discolored spots where it may have gotten hot or where something has been rubbing. you may have to pull off some of the factory wrapping and protectors to see in some spots. if everything looks clean and nice put it back together and try something else. another thing you can try is the valve cover gaskets. they can short out inside themselves you could use an ohm meter to check them too while you got everything apart.
post #8 of 19 Old 04-18-2011, 04:03 PM Thread Starter
Great Melmount and Cowboy.
I'll look into both.
post #9 of 19 Old 04-18-2011, 06:18 PM
get the code checked first, might very well tell you where to look for the problm
melmount is offline
post #10 of 19 Old 04-18-2011, 06:44 PM
sschmidt's Avatar
check the icp sensor for oil in the plug if there is oil in it its bad and will send bad info to the pcm
sschmidt is offline
