My truck died trying to fix quick on the road
My 1999 F250 7.3L - Drove to Missouri to pick up a trailer and made it 10 miles on the way back home to Michigan. Stop to eat and when we came back the truck won't start. These are the symptoms and what I've tried.
- Engine spins fast - No wait to start light but I don't remember one - previous owner bypassed the glow plug system and has a switch on the dash to run them - No smoke from tailpipe - Remove fuel bowl cover turned key and no fuel pumping to bowl - Ran wires direct to the pump and it works - When pump is wired direct truck still doesn't start - No RPMs on gauge when cranking Any ideas what else I should check or what it might be? Truck was running perfect and getting great mileage before this happened. |
truck died
CPS most likely
I would try the cam position sensor after that I dont know for sure
Is this a dealer only part or what part stores carry these? What will it set me back cost wise?
any international dealer should have them if there isnt any close by napa has them as well they should be around $25.00 and easy to install just takes a 10mm socket and a small pry bar of some sort
Napa has them? That would be awesome - especially for that price.
the international one would be my first choice but if you are stuck and napa is your only choice then i would run it till i got home then pick up a spare form international or ford
Napa says they only carry a cam position sensor wiring repair kit. Anyone have a part number I can give them to cut to the chase?
I have the international part #1876735c91 I hope it helps good luck
Napa had a hard time finding it but say they have one for $26.99. Part number CSS1103. Echlin.
