WILL NOT START F350 2000 - Ford Powerstroke Diesel Forum
Old 04-13-2011, 07:14 AM
Question WILL NOT START F350 2000
I HAVE CHANGE THE ECT SENSON AN THE FUEL PRESSURE REGULATOR ,,,,FUEL FILTER ,,,,,IDM ,,,,PCM OR ECM,,,,. PCM RELAY ,,FUSES,,,I TRYED TO PULL START IT STILL WILL NOT START ,,,WILL START IF YOU USE EATHER BUT NO EATHER WILL SHUT DOWN CAN SOMBODY HELP PLEASE WHAT CAN I DO ? TOM EMAIL IS tas47@comcast.net OR PH # 904-686-7122 THANKS
Old 04-13-2011, 10:13 AM
Bad IPR or HPOP?
Old 04-14-2011, 01:33 AM
WHAT IS THE IPR ? OR WHERE IS IT , CHECK THE OIL ON THE HPOP IT IS 1/2 IN FROM THE TOP THAT I WAS TOLD TO CHECK IS THAT WRIGHT ? THANKS FOR REPLY TOM
