Couple of stupid questions???? - Ford Powerstroke Diesel Forum
Old 04-08-2011, 07:31 AM
Just bought a 99 F-250 with a 127-k miles, 7.3L Powerstroke, automatic tranny. Original ol' mans type truck with ZERO mods....
Truck goes down the road great, but noticed a slight miss at idle, has no blow by until I remove the breather lid then there is a light stream of blow by from the oil cap and zero from the dip stick tube.
I know it needs an oil change and would not hurt to chnage the fuel filter and air filter too. Anything else to check or do I need to run te buzz/cont. test as well?
Old 04-08-2011, 08:05 AM
The Tamed Racing Driver
If you think it has a miss at idle then I would do a buzz test and a cylinder contribution test. Highly recomend fluid changes. You never know what the PO (previous owner) thought was acceptable.
Old 04-08-2011, 09:56 AM
By the looks of it the owner just put diesel in it and drove it. It only has a 127-k miles but looks like 300-k...... I run a autocheck and carfax and it shows to be a 1-owner truck with actual miles so I took a chance as cheap as it was.
It might not be a an actual miss just not as smooth as some that I have had. It could very well be just changing all of the filters and fluids and running some fuel treatment in it.
Will run a buzz/cont test Monday after I have it serviced and see what it shows.
