IPR Symptoms? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-06-2011, 01:23 PM Thread Starter
IPR Symptoms?
I am having a few issues with my idle and truck stalling not very consistent and before i go and buy a 190.00 part i wanted to see if anyone can say what the IPR does when failing?
2000 F250 4x4 Supercab Lariat 7.3
AIS Factory Intake
Straight pipe - 5" tip
195k Running strong
Commute 75miles day @17.2mpg
Camoderek is offline
post #2 of 6 Old 04-06-2011, 01:27 PM
Feedback Score: 5 reviews
Have you tried replacing your CPS?
It's only about $25.... i would start there.
Any codes? Fuses good?
ToMang07 is offline
post #3 of 6 Old 04-06-2011, 01:40 PM Thread Starter
I replaced CPS, No codes, Idle sometimes is perfect and it performs same.. but every so often it has a real ruff idle and then stalls... Stalled 3 times while driving = No PS and no BRAKES! so i wanna get it fixed right away but i would hate to spent 200 on the part and it not even be that...
AIS Factory Intake
195k Running strong
post #4 of 6 Old 04-06-2011, 05:25 PM
a friend of mine told me that an IPR would be a bit cheaper at international rather than from ford. Don't know how much is true but may try and check it out.
eighty3bronco is offline
post #5 of 6 Old 04-07-2011, 05:04 AM Thread Starter
I am getting the part in a hour any last bit of input?
AIS Factory Intake
195k Running strong
post #6 of 6 Old 04-07-2011, 03:34 PM Thread Starter
Problem solved... When i went to remove the IPR i noticed the pig tail plugged attached to it had 3 wires all three were twined together and had elec tape hanging off them leaving an exposed wire that was touching each other causing the problem. I cleaned wired then soldered them and heat shrunk all 3 wires then wrapped them problem solved.
AIS Factory Intake
195k Running strong
