Oil leak from line on top of pass valve cover (What's the line) - Ford Powerstroke Diesel Forum
Old 04-06-2011, 11:03 AM
I have oil pooring out of a line going into my topside passanger valve cover, It has a nut on it. How do I fix that or what does the line go to?
Thanks
Old 04-06-2011, 11:28 AM
Got it, HPOP line, Now where do I find it, Calling nAPA
Old 04-06-2011, 11:38 AM
Hopefully just an o-ring for the line. Bob is very knowledgeable, and great to do business with.
Replacement O-rings for Ford Diesel Engines
Old 04-06-2011, 01:11 PM
I just bought the fittings and line. I have loosened the valve cover fitting already, Do I remove the line from the fitting before I remove the fitting, Or should I put everything together first, Then install the fittings? (With the line already attached).
Old 04-06-2011, 03:52 PM
Did the fittings first then put the line on, No leaking. Line 150.00 fittings 100.00 total and oil 40.00. I repaired it in a truck stop parking lot with basic tools I have. Very easy repair, I had to remove some tubes/lines and crap, But repair took me 2 hrs remove/install.
Back On the road now, Heading to Grove,OK-Chicago-Goshen-San Antonio.
Thanks
Old 04-07-2011, 05:52 AM
Glad it worked out for you. Thanks for the follow up report.
