Idle cconcern.. - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-01-2011, 07:09 AM Thread Starter
Idle cconcern..
I am noticing a idle issue in my truck, it does not do it all the time but sometimes I'll be at a traffic light and the idle will jump up and down and smooth out after a couple seconds. I also noticed sometimes when coming to a stop light as I am breaking the idle is hi 1k until I completely stop.. These things are not consistent any ideas? Should I worry? It stalled yesterday for first time ever so I worry it's getting worse...
2000 F250 4x4 Supercab Lariat 7.3
AIS Factory Intake
Straight pipe - 5" tip
195k Running strong
Commute 75miles day @17.2mpg
Camoderek is offline
post #2 of 14 Old 04-01-2011, 07:38 AM Thread Starter
Just now stalled was running perfect I noticed a weird chugging as I coasted to light when I made my right hand turn it just shut off as I was rolling I popped into neutral and fired right up.. Now running.. I ran through a few puddles yesterday could that be it?
AIS Factory Intake
195k Running strong
post #3 of 14 Old 04-01-2011, 08:40 AM
cant hurt to put in a new cps they run about 20 bucks. they usually cause complete dying but will start right back up no problem. I would start there.
bjg8599 is offline
post #4 of 14 Old 04-01-2011, 09:04 AM Thread Starter
That's what my mechanic said to do just to rule it out.. So I'll start there
AIS Factory Intake
195k Running strong
post #5 of 14 Old 04-01-2011, 12:54 PM Thread Starter
Ok new CPS and still have a rough idle from time to time not constant and it still spuddered out and died once.. The truck drives like normal all the issues are happening at idle. Yesterday i ran it nearly bone dry AND drove through some flooded streets. I filled up today added some Diesel Kleen like i always do and now have these issues. I wanted to add as much info as possible in hopes you all have some insight.
AIS Factory Intake
195k Running strong
post #6 of 14 Old 04-01-2011, 03:33 PM
next try ipr.
bjg8599 is offline
post #7 of 14 Old 04-01-2011, 04:03 PM Thread Starter
next try ipr.
IPR? Where is it what is it?
AIS Factory Intake
195k Running strong
post #8 of 14 Old 04-01-2011, 04:06 PM
When was your last fuel filter changed??
FordPowerStroke1986 is offline
post #9 of 14 Old 04-01-2011, 04:28 PM Thread Starter
about 4k miles ago
AIS Factory Intake
195k Running strong
post #10 of 14 Old 04-01-2011, 05:01 PM
it is on the drivers side in front by valve cover, type in ipr on google then click images. but actually i was wrong you shoud check the icp(injector control pressure sensor) and make sure it doesnt have oil on the bottom of it. you can try a loop test on it but sometimes this test doesnt work, start the truck let it warm up then unplug icp and if it smooths out then that is your problem. sometimes it wont smooth out and it will still turn out to be the icp. the ipr and the icp work together to adjust the pressure of oil being sent to the injectors. neither sensor is cheap.
bjg8599 is offline
