- REGISTER - SITE HELP - ARCADE - STAFF - MEMBERSHIP - GET A QUOTE - ADVERTISE - CONTACT US -
Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 10-05-2005, 04:38 AM
fast idle
can someone tell me what sensor or sensor's control the fast idle on a cold engine. My 02 psd would idle up to about 1100 rpm on its own, my 99 will not.
Old 10-11-2005, 05:47 PM
does your cruise control work? my fast idle quit working on my 2000 found out it is linked to the clutch pedal switch. when that switch is broken the truck thinks that the clutch is in so the idle will not kick up.. it's a medium sized black and white cylinder looking thing. that slides back and forth on the clutch pedal rod. It is spring loaded and when broken it doesnt slide.. Hope that helps
Old 10-24-2005, 02:20 PM
Is your 99 a superduty or the lighter duty. I think only the super duty has the idle up option (99.5). Also there is a sensor on the airbox of the superduty that mesures the air temp. Hope this helps!
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
