2000 F350 - Too Much Torque!!! - Ford Powerstroke Diesel Forum
Old 03-14-2011, 04:15 AM
Truck is the one in my sig.
I just put the injectors in about a week ago. The truck now makes so much torque the motor is twisting and the serpentine belt is now hitting the upper radiator hose under a hard launch. I have had the hose blow off once and I have been through 3 belts since the injector install. When the belt his the hose it pushes it back and the pulleys and shaves the back 2 ribs off the belt. Motor mounts are STOCK but only have about 25k miles on them.
Has anyone ran into this problem before. Do I need some better/heavier motor mounts? Do I need to chain it? I know there are a lot of guys running the same combo as me (38r and stage 3s) so if any of you guys could chime in that would be awesome.
Thanks!
Old 03-14-2011, 10:13 AM
30 views and no comments???
Do you guys just think I got some bum motor mounts before. Nobody has ran into this problem???
Old 03-14-2011, 10:18 AM
Feedback Score: 5 reviews
Thats kinda what I was thinking.... either bad or not properly installed.
But IDK.
Old 03-14-2011, 10:20 AM
riddin' high
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
Im also interested about this, thats about the same set up i will be running soon and may change my mind if i will have this problem and not be able to fix it
Stiffer motor mounts may help, but they can only do so much, if there are "too" stiff and the engine torques and twists.........breaking the motor mount clean off wouldnt be fun at all
Had the truck on the dyno yet? Interested to see the #'s it lays down with the 38r and 3's versus the h2e and 3's
Old 03-14-2011, 10:40 AM
Well I know the mounts are installed correctly. Probably just bum mounts (I think they came from autozone or something like that) so they are probably junk. I have not had it on the dyno, I just got it all done about a week ago. I can tell you that you will not be disappointed with the combo. I cannot believe the power I am making with my setup. I do believe you have PMR's though and if you do I wouldn't run stage 3s.
Old 03-14-2011, 12:42 PM
You could always run a torque strut to help minimize the twist. .....
Old 03-15-2011, 03:21 AM
I am not familiar with what a torque strut is. Could you explain a little more?
Old 03-15-2011, 04:16 AM
I'm no help but bump for a B A truck
Old 03-15-2011, 04:20 AM
Thanks yours sounds pretty BA to judging by your sig!
Old 03-15-2011, 06:18 AM
completely off topic, but why did you go with the ats trans over a bts one? You have the exact setup I want
