Oil coming from pcv - Ford Powerstroke Diesel Forum
Old 03-10-2011, 07:06 PM
Oil coming from pcv
I replaced my valve cover gasket tonight on the driver side and found oil getting into my intake air from the pcv on valve cover. Anyone ever seen this?? Should I replace the PCV??
Old 03-11-2011, 06:54 AM
PVC?
Is this, as your nick indicates, an '86?
What you're looking at is the CCV emission system (no "valve" though) and he migration of oil into the Turbo & IC and contamination of the IC Boots is common.
The solution is called a CCV MOD, I've done mine as have Many members here, and a simple solution to the problem.
Old 03-11-2011, 07:33 AM
I don't know what you're talking about but it's the black box on the of the driver side valve cover. What's Ccv stand for.
Old 03-11-2011, 08:02 AM
CCV = crankcase vent and that is what you are looking at.
Old 03-11-2011, 08:58 AM
You're gonna have to trust me here we're talking about the same thing....
I've given you the solution to separating the oil from the blow-by now going into the intake. It's up to you to read-up on it
Old 03-12-2011, 06:20 AM
I did the mod for that same reason. oil in intercooler system
