95 7.3 Oil in the fuel??
I have a 1995 ford f350 with the 7.3, we use it to pull out 5th wheel camper, on the way home from the lake last fall it started loosing power, and not much oil on the dipstick, right after an oil change, no more than 100 miles on the change, so we filled it back up with oil and installed a new fuel filter on the side of the road, when we removed the filter it was filled with oil. it sat for a few weeks then i replaced the lift pump, the one in the center of the valley. now we drove it for maybe 10 miles around town and went to pull it out of the shed this spring and its doing the same thing again, any suggestions?
I have read on some of these forums that it may be a hi pressure oil pump, then other people i have talked to say they almost never go out on these years, could it be the injector o rings?
I have no problem working on it my self, I'm just trying not to throw a bunch of money at the wrong problem.
thanks in advance
