the dreaded rotted oil pan! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-21-2011, 07:19 AM Thread Starter
2000 CC LB
my oil pan is rotted. I have leaked a gallon of oil in the past week. I crawled under the truck to have a look and found the previous owner had mad a shoddy jb weld repair and sprayed it black...I am pretty cheezed off!
I cleaned it up and sprayed cleaner on it to degrease/de oil it. I spead long hair fiberglass all over the deep sump section minus the drain plug area. I still have a small leak though.
should I clean it up some more and put more fiberglass to it?
BTW I am doing this to get by till warm weather (I am in northern maine) and then the engine is coming out for a build!
thanks for any help in advance
redpowerstroke is offline
post #2 of 3 Old 02-22-2011, 03:16 AM Thread Starter
forget it...the engine is coming out!
while she is out I am going to do the bellowed up pipes too. can you guys think of anything else I should do? must do while engine out?
post #3 of 3 Old 02-22-2011, 03:43 AM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
Port and polish the heads if you know how.
Do a custom fuel system.
ARP head tuck are always good insurance not needed but if you want big power
headers
rear main seal just incase it goes bad you dont have to take the engine out again.
2002 f250 BFT Edition
dereku is offline
