03 7.3l idle but wont rev - Ford Powerstroke Diesel Forum
Old 02-18-2011, 05:46 PM
i have an 03 f 250 7.3l will fire right up to an idle. press the pedal wont rev up. bought new pedal no change. cant seem to figure it out. been told a many of things like boost sensor, icm, tps. trying to get a better and narrower opinion than to buy all these parts to fix it. new to here and new to powerstrokes what a accelerating welcome. haha
Old 02-18-2011, 05:54 PM
throttle position sensor
Old 02-18-2011, 06:02 PM
Illiana Chapter Director
Check your fuses and check the wiring in the column that goes to the OD on/off switch
Old 02-18-2011, 06:03 PM
i didnt think was injection control module because that wouldnt even send fuel to start it up right? i will try the throttle position sensor and see what happens from there thanks
Old 02-18-2011, 06:04 PM
all fuses are good the over drive column switch has been cut off wires are still there bought the truck to fix and have done all i know trying to get advise
Old 02-18-2011, 06:06 PM
lol wth would that have to do with no throttle response me lost....
Old 02-18-2011, 06:10 PM
Because the wiring for the TPS is also part of the wiring to the OD switch. OD switch wire breaks or rubs through, blows fuse, no throttle
Old 02-18-2011, 06:12 PM
idk but asume truck has had some problem with overdrive switch cause it is no longer there just two or three wires hangin.
Old 02-18-2011, 06:14 PM
lol oh ok... good thing I havent slept in 24 hours or I wouldnt have an excuse for being a tard lol
Lol well then a yup, i believe a problem be there.
I'd pull the column cover and inspect the wiring for chaffing. If you see any, repair wire and install new switch. I'll bet it was removed because it kept popping the fuse and the previous owner didn't know where to look.
