coolant leaking from behind TURBO - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-18-2011, 10:57 AM Thread Starter
mdkallam130's Avatar
Send a message via AIM to mdkallam130
when i add coolant to my truck it seems to drain fairly quickly and starts to leak right behind the turbo...
can anyone tell me why and how the water is getting from the over flow bottle to just behind my turbo and leaking badly?
2002 F250 Crew Cab 4x4 7.3
35x12.50x17 on a set of 2005 F250 Wheels
S&B air intake customized
4"turbo back straight pipe with a 5" tip,
gauges
DP TUNER - on its way
wish list.
5"turnout stacks,injectors,bigger turbo, bigger hpop, fass system, Built Transmission
"I'D RATHER BE JUDGED BY 12 THAN CARRIED BY 6"
mdkallam130 is offline
post #2 of 2 Old 02-19-2011, 01:43 PM
I think the heater lines are about the only thing that go back there that might leak, but you should be able to see them as they go to the firewall on the passenger side. Aside from that, it would almost have to be a external leak from the head gaskets. Maybe a boroscope or a mirror and a cold pressure test would help. Doesn't sound like much fun!
Cgaetz is offline
