Blowing Air?? Stuck Valve?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-11-2011, 09:51 PM Thread Starter
X-Hare's Avatar
I just started to get this strange blowing air sound when holding steady RPM when I give it a little fuel it all of a sudden shuts off then comes back seems to stop after running awhile.
Any thoughts appreciated
X-Hare is offline
post #2 of 11 Old 02-11-2011, 09:54 PM
dieseldik's Avatar
check your cac (charge air cooler) hoses probably a loose clamp
dieseldik is offline
post #3 of 11 Old 02-11-2011, 10:01 PM Thread Starter
X-Hare's Avatar
Would that be on the rear passanger side?
X-Hare is offline
post #4 of 11 Old 02-11-2011, 10:06 PM
spool up that turbo!!
hollister25073's Avatar
if it does it when its cold its your exhaust back pressure valve
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
boost pyro and engine oil temp
AIH delete, hpx, frx
05 harleys 8000k's
billet grille and painted shell
17"welds and 35-12.5's toyo mt's
cab lights
southbend con ofe waiting to go in
fresh 7.3 from reviva
SOLD
1995 f150 302 5spd 35's sad sad day
hollister25073 is offline
post #5 of 11 Old 02-11-2011, 10:09 PM Thread Starter
X-Hare's Avatar
I should add 99 F350-sorry---But I'm thinking valve too its a real snappy shut-off then as the Rpm drops it opens again.
Where do I find this beast and is it a repair something that can be attempted by a novice ?
X-Hare is offline
post #6 of 11 Old 02-11-2011, 10:11 PM
dieseldik's Avatar
there are 2 pipes one on each side of the engine going towards radiator i believe most call these intercooler pipes but any way check the hoses at both ends of each pipe( 4 hoses total) and check the clamps or see if they have popped off!
post #7 of 11 Old 02-11-2011, 10:14 PM
dieseldik's Avatar
oh by the way if you dont notice a horsepower loss then i'll go with hollister25073
post #8 of 11 Old 02-11-2011, 10:21 PM
late_99_PSD's Avatar
Quoted: 10 Post(s)
Definately sounds like EBPV. If it only does it when its cold and shuts off as soon as you hit the throttle then its workig properly. But if it feels like its coming on under load and holding you back then you can uplug it.
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #9 of 11 Old 02-11-2011, 11:07 PM Thread Starter
X-Hare's Avatar
No horsepower loss --- just this loud annoying hissing sound.
Any idea if this is an easy fix?
X-Hare is offline
post #10 of 11 Old 02-13-2011, 09:17 PM Thread Starter
X-Hare's Avatar
Today I think I found the exhaust back pressure valve
has a small pipe vent coming from the assembly
Probably got a bunch of crap splashed up in there.
X-Hare is offline
